O.C.T. Jackson River – Gathright Dam Pulse Release- Wed, 7/17/24
PaddleBear
Post by PaddleBear »
Background - Periodically (once a month in late spring, summer, and early fall), the Norfolk District in coordination with the Virginia Department of Environmental Quality and the Virginia Department of Wildlife Resources, releases excess water from the Gathright Dam Army Corps of Engineers - https://www.nao-wc.usace.army.mil/nao/projected_Q.html The pulse is drained from the bottom of the reservoir and therefore the water temperature is ~50 F. This “pulse” of water is released into the Jackson River starting at approximately 6 a.m. and ends at 1:30 p.m. We have found that starting our paddle at ~11:00 AM (peak of the water release which is level with the water gauge house wire platform boat launch) is optimal. Starting at 11:00 – the pulse release is cut back and the peak water goes down by about .5 inches per minute (by 11:30 the water level is 8-12 inches lower than the wire platform boat launch). The 11:00 start allows for the most dramatic wave trains. This peak water level also washes out much of the river bank debris, mud, and the water runs clear. The peak pulse release will be 3,500 cfs and will increase levels 3 to 4.5 feet in the Jackson River producing excellent and fun wave trains.
For those new to the “pulse” release, this is a swift 17-mile class I – II+ run (approximate 3.5 hour run), with several excellent class II+ wave trains blended with periodic Class I riffles to give you a break from the excitement. There is one class III- rapid (~200 yards long) right below the dam. You can choose to run it or skip it, your choice. Usually, about 25% the group runs the top class III rapid and the other 75% puts in just below the rapid at the water gauge house wire mesh boat launch.
Remember, this is a dam release. The water will be cold (high 50 F), so dress appropriately. The flow will be high, so anticipate strong and erratic currents in places. Even though this is a relatively easy run with very few obstacles to navigate, the high flow necessitates that everyone be strong swimmers. This is not a new beginner run; this is a high beginner/low novice minimum run. Only experienced Class II+ paddlers on the top Class III rapid, please. Optimal boat choice would be a white water boat with some rocker to the hull design to efficiently ride the wave trains. Recommend a water proof roll skirt if you have one. Alternatively, a canoe with float bags and a skilled canoeist do very well. Several of us have run this pulse many times with a recreational kayak – bring a spray skirt if you have it and you will most definitely need a bailing pump as wave train splashes of water enter the boat at each wave train. Sit on top kayaks are not recommended with the exception of those rated for Class II (e.g., Liquid Logic Coupe).
We will launch from the wire mesh put-in at the water gauge house at ~11:00 with the peak water level of the pulse and the riven water is level with the wire mess cage launch point. We will launch in buddy boat groups (stick together for potential water recovery assistance) of 2-6 boats. Maintain appropriate distance during rapids to enable good maneuverability of each boat.
We will stop river left at approximately half way for a 30-minute lunch/leg stretch break just after Smith Bridge at the Smith Bridge River Access (river left). Excellent dock and landing/launch on bank with a beautiful field to catch shade or sun. There are no restrooms or potable water. Critical that we don’t get back on the river too soon (we will catchup to brown water/debris) or too late (we will miss the right level to maximize wave train fun).
We will end the day river left at the public park next to Alleghany Outdoors, 1903 Dressler Dr, Covington, VA 24426 @ ~3:00-3:30. Look for a large orange ball hanging in a tree mid-river – directing you river left – then look for a field lined by a wooden fence. At the end of the fence is the concrete boat ramp.
Weather – will likely be in the 60-70s at this time of year. This is an all-weather go event.
Schedule:
Meet at the take out at the Intervale Trail Head (Public Park), 1903 Dressler Dr, Covington, VA next to Alleghany Outdoors, 1903 Dressler Dr, Covington, VA 24426 @ 10:00 sharp. There is ample parking at the park, flush toilets, and potable water. Timing on the pulse is everything, please be prompt (we don’t want to miss those exceptional wave trains)! Depart by 10:15 to shuttle boats, people, equipment to put-in.
Goal is to be at the put-in at Gathright Dam, 100 Stilling Basin Road, Hot Springs, VA at 10:30. If you are planning on running the top Class III section from the dam to the water gauge house, please put in at the base of the dam immediately and meet the rest of group at the water gauge house wire mess boat launching area NLT 10:55. There has historically been porta pottys and no potable water at the base of the dam and no porta pottys or potable water at the water gauge house wire mess boat launching area.
Please respond to this posting or text me to let us know you are going. Don’t just show up with no notice. Having an accurate head count helps in the efficient shuttle planning.
Bring a lunch and plan to spend the day with us. It is a good idea to bring a change of dry clothes for after the run.
Plan on joining us for the remaining Pulse Releases Schedules for 2024 posted at - https://www.nao-wc.usace.army.mil/nao/projected_Q.html :
• JULY 17
• AUG 7
• AUG 28
• SEP 18
• OCT 9
Brian
Brianschultz22@protonmail.com
Text at 703-627-9922
See you on the river,
PaddleBear (Brian)
Experienced (Class III)
Liquid Logic Remix XP10 (white water), Wilderness Systems Pungo 140 (touring)
RangeRon78
Eddy Flippin'
Eddy Flippin'
Re: O.C.T. Jackson River – Gathright Dam Pulse Release- Wed, 7/17/24
Post by RangeRon78 »
I plan to be there. It's been far too long since I've been on moving water in Virginia and I'm sick of being stuck inside because of the heat! I probably will not run the rapid just below the dam this trip.
Philmont Ranger--1978
RangeRon78
Eddy Flippin'
Eddy Flippin'
I should have mentioned that I would be glad to drive or share a ride from the Charlottesville area if anyone else is going from here or somewhere enroute from here. I have a Honda CR-V with a roof rack and will be bringing my IK (deflated) and gear.
Not sure my Coastals forum profile has up-to-date information on me. My mobile number is FourThreeFour-NineSixOh-SixSixSixFive and my current Gmail email address is my name (Ron Wiley Jr) without caps or spaces.
RangeRon78
Eddy Flippin'
Eddy Flippin'
I've just gotten a call from a good friend who was a streams and rivers monitor for DEQ before he retired. He'd like to join me just for the ride and to see the effects of the pulse on the river levels, so I'll definitely be driving from Charlottesville and we'll have an extra driver to help with setting the shuttle. He may join us on the river in August for the next pulse release but is just interested in seeing it this time.
PaddleBear
Glad you and your friend will be joining us for the pulse. There are others that are coming from Charlottesville. Mine is brianschultz22@protonmail.com 703-627-9922. Nice to have a Philmont Ranger on the paddle - 2 of us are former Scout Masters and my son just came back from the trip up Old Baldy.
PaddleBear (Brian)
RangeRon78
Eddy Flippin'
Eddy Flippin'
I sadly decided I should not do this trip tomorrow. I'm really sensitive to heat and am concerned about overheating in a wetsuit but unsafe in the cold water without one. (It didn't help that I really struggled to try on my wetsuit yesterday after a few years of it being stored with my gear - I'm sure it must have shrunk in the meantime!) Anyway, better safe than sorry. I really hope the heat spell will break and I can join everyone for one of the later releases. (Maybe I'll go on a diet for the next few months!)
